Have been using Bughead 6.89 for sometime now and Im generally happy with the results. Though the play time and track stop time is higher than previous versions. Can't try higher versions as I am on Win 7.
Reading about Hysolid, tried that as well. For starters, I shared only one album to check out the ease of use. Pairing between PC & Mobile is extremely fast. No lag, no glitches. SQ is a bit more congested than Bug but overall far better than Foobar. I found it extremely convenient and considering the advantages over Foobar, would like to use it as my primary player for a while.
But here is an issue I am getting. I linked a music folder which has about 780gb of content. It has been almost more than 72 hours that Hysolid is trying to create a list of the sound source but it has not yet ended. Earlier also I attempted this but when it dint happen in say 5-6 hours, I killed the process. Later I thought maybe I killed the process in haste so lemme attempt again. It certainly does not seem to be the case here. Can anyone else corroborate if they also faced such a challenge? Has anyone linked such a big folder with Hysolid and has been successful in building this network library?
