sam9s
- Joined
- Aug 25, 2009
- Messages
- 5,247
- Points
- 113
Thad,
Could you pls explain in simple terms what you would reccomend as a setup, if one needs more than 4 LAN ports.
I use a Beetel DSL modem, and a Linksys Wi-fi Router. I have used up all the ports on the router. Its a very old one, and I was planning to replace it with a router with more than 4 ports. The only one I found, is :
WD My Net N900 HD Dual-Band - WD: Flipkart.com
Its expensive, but reviews are good.
What would be your reccomendation for a simple but effective setup ?
Rgds...Argho
If you need more ports, go for a switch not a router, unless you plan to create another wifi zone somewhere else in your house ......
Keep the existing router, get an 8 port switch connect it with the router and there you go, you have 7 ports in hand now .....
