bhalakumaran
Hello All,
I would like to state upfront that i am a novice when it comes to audio systems. Hopefully will make a clear point of what i am looking for.
To explain my setup, I have
From what i have looked up so far, It is my understanding that there is no easy way to have a good 5.1 Surround sound without a dedicated AV Receiver.
To set up a good surround system I believe i have to do the following,
Will this setup work ? Is there a better way to do this ? Please suggest.
I have not yet bought the AV Receiver or the speaker system. It would be great if anyone can suggest me a entry level AV Receiver and speaker system that are available in India,budget being 15-20k
Any help will be greatly appreciated.
Thanks,
Bhalakumaran
Sony Bravia HDTV - KDL 40 EX520 (4 HDMI In, 1 Digital Optical Out, 1 3.5mm Jack audio out)
Airtel Set-top Box with HD Connectivity - ( HDMI Out , S/PDIF Out)
PC with HDMI Out.
Connect the set top box to the receiver through the HDMI Cable.
- Connect my PC to the receiver through the HDMI Cable.
- The 5.1 System to the receiver through the dedicated connectors in the recievers.
- Audio out from the TV to the receiver though either the 3.5mm Jack / Digital optical out.
- Able to watch movies / play games with 5.1 sound from my PC.
- See Dolby Digital supported shows from my set-top box.
- Switch between either cable / set-top box / PC outputs.
Thanks,
Bhalakumaran
