Car CD Player Lens Problem
kups007
Ok i am not among the Hi-Fi ones cos cant really afford it
anyways i own a Sony Car MP3 Audio System 52Wx4, I dont remember the model no with 240W Blaupunkt Speakers
and in due course of time one of my MP3 CD got stuck up, so showed it to my vendor, he says that the lens is gone
what do the mods suggest shall i do ??
How much will a lens cost ?
is it advisable to go for lens change ?
Pls suggest
Pls suggest
If the cd is stuck, it couldn't mean that the lens is 'gone'. There's a problem with the eject mechanism, and it's generally easy to solve. I suggest you take a second opinion.
