Hi Evryone,
I'm new to this forum
I wanna know about Home theater or AVR+5.1 speakers
I have a PC config, which i use for Gaming, watching movies + TV series :
I was going to buy a 5.1 multimedia Speakers for PC, until I read about buying a Home theater or AVR+5.1 speakers with Remote by which i can connect PC/Laptop/TV/ipod/PS3
I dont have much knowledge of good brands and also don't want to spend much.
what I want in AVR/HT is:
also please suggest what features should i look out for,
PS:
If branded HT price >> AVR+5.1, then please suggest AVR+speakers
or if AVR+5.1 >> HT, then please suggest HT
PS: I wud spend from 6k to 10k, willing to save money and buy later if budget exceeds.
Also is there is any other cheaper multichannel setup which can work with PC/Laptop/TV/ipod/PS3???
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
- Mobo: MSI 890GXM (Inbuilt 7.1 Realtek Sound Card and AMD SPDIF optical)
- Proc: AMD Phenom II X4 970 BE
- RAM: 4 GB DDR3
- GPU: Zotac 450GTS (2GB) - using mini HDMI port
- Display: 32" LCD panasonic (2xHDMi ports, 2XAVi Ports), connected to PC via HDMI 1
- OS: Win 8
- Atleast 2 HDMI IN and 1 HDMI OUT (so that PC is always connected),
(or) 1 HDMI IN + OPTICAL SPDIF IN and 1 HDMI OUT
Edit: As my mobo has SPDIF optical,it would work out by connecting PC mini-HDMI OUT to TV HDMI1 and SPDIF optical to AVR/HT - USB INPUT - play music and movies from pen drive
- 3.5mm Input - to play music from ipod/mobiles
- Sound should not clitter or distort
- FM may be optional
- Auxillary out may be optional
- Also i dont require collumn speakers as they will be costlier, i can go with wall mounted speakers/satellites.
PS:
- Idk if 300w or 1200w is enough (I'm gonna use it in my room)
