I had same confusion 3 months before. Then settled with Sony X9000F. This one replaced my Sony LCD HD TV of 12 years old which works fine (it works fine even now) with the history of zero issues irrespective of very poor power fluctuation.
Here is the yard stick I prepared to zero down to Sony LED against LG OLED. It may be useful for you too. Give weight-age to these points based on your requirement. It varies.
1. OLED gives best contrast. But on other hand OLED causes Black crush i.e., lost of grey shades in black | ||
2. If watching TV on brightly lit room, go for Sony LED. If dark room, go for LG OLED | ||
3. If watching TV from very very wide angle go for LG OLED or go for Sony LED | ||
4. If watching TV on brightly lit room, go for Sony LED. If dark room, go for LG OLED | ||
5. Deal breaker: Risk of Burn-in and lack of warranty in LG for the same may be deal breaker for you. It is up to your risk taking ability. No one has exactly figured out what pattern of viewing causes burn-in. | ||
6. If most of the contents are low fps (24/30), it causes poor stutter in LG OLED | ||
7. UI lag fixed in latest Android Oreo FW update in Sony. But after update also it is crap. Since I plan to buy Nvidia shield Android TV box, I don't mind and skipped this flaw. If you don't have such plan, it is frustrating in everyday TV watching. | ||
8. If you are not keen on Android TV, LG OLED may be good one. It has silky flowing UI with most used apps (the most missed one - HotStar also recently added). | ||
9. Good remote? Go for LG. The worst remote? Go for Sony ![]() | ||
