shrajan673
Iam planning to buy Yamaha yht 2910 this diwali. But I have few doubts in connecting the same to my tv. Here is my situation:
1. I have Samsung EH6030R. It has just two HDMI ports, 1 USB port, 1 component input and 1 av input
2. I have airtel HD stb, Xbox 360 and an old Philips DVD player
3. Might get a blu ray player (not sure as of now)
My problem is whether I can connect all the above with Yamaha yht 2910 in such a way that :
1. When I use stb, I should listen sound through my 5.1 (and also in tv)
2. When I play movies through USB in tv, I should get audio from my 5.1 ( and also in tv)
3. When I play in my Xbox, I should get audio from my 5.1 (and also from tv)
4. The above said situation in case of my DVD player too.
Theoretically,
If I connect all the sources to av receiver (inputs) and connect my tv and av receiver (through receiver output) all with HDMI (except for DVD player which will bw through av connections- video to tv and audio to htib), is that possible ???
It will be very helpful if you guys guide me. Thanks in advance !
Theoretically,
