Hello All,
I am new to this forum and quite pleased to post my first query to take recommendations from the audiophile experts on this forum.
Based on this forum discussions, I have purchased Norge 2060 and Boston Acoustics A26 speakers to realize a 2.0 setup (no sub) combo.
Now I have a need to connect this setup to my LED TV which in-turn is already connected with a TataSky set-top box on HDMI-1 and DVD player on HDMI-2.
The following are the couple of queries:
1) Should I need to connect the TataSky set-top box and DVD player audio outputs to Norge 2060 "AUX" and "DVD" audio-IN ports respectively via 2-pin RCA cable (White & Red)
OR
Alternatively should I connect my LED TV Headphone output to Norge 2060"AUX" audio-IN port via 3.5mm to RCA cable.
Which one is the best method wrt sound quality.
2) Wires to be used for connecting Norge 2060 to speakers. Should I need to go for standard speaker cables eg. DAC 14 or can I use Finolex 2.5 sq. mm household electrical cable. Which is best wrt sound quality. Planning to terminate the speaker cable with Profigold 4mm banana plugs at both ends.
I am writing from Bangalore and maybe suggestions on any good store from where I can get the above required interconnects & cables (5ft + 5ft) would be of great help too.
Looking forward for an early response.
Thanks,
Rajini
OR
Thanks,
Rajini
