Converting a small bedroom into a dedicated HT
thanks for the advice man!! what sub would you suggest in similar price range
A decent sub would atleast cost you 30k. And also you should go for a dual sub for even and smooth bass. Bic f-12, Yamaha sw 300, Taga harmony are the only subs I can think of in that range
thanks man. I'll go for dual bass later. I'm getting the wiring done for two now. will get another sub later
Cool. Dual subs are the way to go. Bic f-12 I have heard in two set ups and it was amazing. If budget constraints you can very well go ahead with sw300
I'm converting a bedroom into a dedicated home theatre room. My room is 11ft x 14ft. I have a budget of 3.5-4L. i have narrowed down on the projector which is BenQ W1700 for which i have gotten a quote of Rs. 1.42 from a local dealer. The local dealer over here in Jaipur has given me the below quote
Bose 40SE x 3 = Rs. 40829 x 3 = Rs. 122487/-
Bose 16S x 2 = Rs. 16520 x 2 = Rs. 33040/-
Bose 16F x 2 = Rs. 11210 x 2 = Rs. 22420/- (Atmos)
JBL sub100 = Rs. 23600/-
Denon AVRX 7.2 = Rs. 49560/-
Screen 110" - Rs. 29500/-
HDMI - Rs. 5900/-
Projector kit - Rs. 1000/-
Total - Rs. 444687/-
After final discount - Rs. 425000/-
Another option for audio is as below
S.No.MakeModelQtyUnitGSTUnit PriceUnit Price After GSTAmount
Pathway
1JBLArena 1702Nos.18%18000 21,240.00 42,480.00
2JBLArena 1251Nos.18% 12,500.00 14,750.00 14,750.00
3JBL6ic2Nos.18% 8,000.00 9,440.00 18,880.00
4JBlArena 120(Pair)1Nos.18% 15,000.00 17,700.00 17,700.00
5JBLSub 1001Nos.18% 20,000.00 23,600.00 23,600.00
6DenonAvrx 24001Nos.18% 55,000.00 64,900.00 64,900.00
Guys i have have a very minimal understanding of this stuff as this would be my first build so i need your guys help in narrowing down the audio setup.
Thanks a ton in advance.
I guess rather than bose , qacoustics 3010i with center 3090ci will give you much better experience and with much better sound quality. Also more reasonable price.
Also 3010i can be hanged on wall.
