Eversolo z8 and cambridge audio dac magic200m. Both support MQA.Go for eversolo z8
Having marantz 50 and klipsch ref.In my opinion, an expensive DAC for an AVR is not gonna improve much. What AVR and speakers do you use? You may invest in a good 2 channel amp and DAC for music listening.
And want to build audio for bedroom with z8 dac,In my opinion, an expensive DAC for an AVR is not gonna improve much. What AVR and speakers do you use? You may invest in a good 2 channel amp and DAC for music listening.
Going to get 0&b power amp in this month. Delivery exoecting .
In that case you can go with a DAC now.And want to build audio for bedroom with z8 dac,
Indiq speakers later.
Had iPhone 16plus. How to get High resmusic 24bit 192khz lstream through dac or avrIn that case you can go with a DAC now.
I connect my iPhone 15 using USB-C to USB-C on Mojo 2 and it works well and I can see 24/96, 24/192 streamed. Does your DAC have a USB input? if yes, it should work I guess. There are adaptors for non-USB C inputs on DAC that you can have a look at.Had iPhone 16plus. How to get High resmusic 24bit 192khz lstream through dac or avr
I have ordered Eversolo z8. To be received my tomorrowsI connect my iPhone 15 using USB-C to USB-C on Mojo 2 and it works well and I can see 24/96, 24/192 streamed. Does your DAC have a USB input? if yes, it should work I guess. There are adaptors for non-USB C inputs on DAC that you can have a look at.
Where you bought cableI connect my iPhone 15 using USB-C to USB-C on Mojo 2 and it works well and I can see 24/96, 24/192 streamed. Does your DAC have a USB input? if yes, it should work I guess. There are adaptors for non-USB C inputs on DAC that you can have a look at.
The USB-C to USB-C is the stock cable I got with the iPhone 15. And I do see the Z8 has a USB-C input as well on the back panel. I think iPhone 16 does come with the charging cable which is type-C to type-C, based on the description given on Apple website.Where you bought cable
if it is apple music, go via usb c on your phone to usb to the dac method. If you use qobuz or something, install it on your zidoo and stream to the dac from there.Had iPhone 16plus. How to get High resmusic 24bit 192khz lstream through dac or avr
Notmal optical cable from bluerigger is sufficient to connect Eversolo z8 for time being as my coaxial cable in transport. Dac I will receive max today.The USB-C to USB-C is the stock cable I got with the iPhone 15. And I do see the Z8 has a USB-C input as well on the back panel. I think iPhone 16 does come with the charging cable which is type-C to type-C, based on the description given on Apple website.
Today connected iPhone 16plus to z8 using Usb c port. And try to play song. But not abke to get sound.I connect my iPhone 15 using USB-C to USB-C on Mojo 2 and it works well and I can see 24/96, 24/192 streamed. Does your DAC have a USB input? if yes, it should work I guess. There are adaptors for non-USB C inputs on DAC that you can have a look at.
I haven't used this with latest USB-c but in past in order to connect any Apple device such as iPhone or iPad, I had to use Apple's camera kit. Direct connection did not work that time.Today connected iPhone 16plus to z8 using Usb c port. And try to play song. But not abke to get sound.
Chain: matanz50 through Rca to Dac
Iphone through usbc Dac
