But now tou can see the difference in projected area and the rest. Room became dark and pictures became high contrast.
Are you talking about grey screen paint or grey screen material? I've done a reasonable amount of painted grey screens.
How much would a grey screen (fabric) improve upon a ivory screen (fabric) for contrast ?..
I have experimented with a DIY Dark Gray screen!
Grey screens work best with bright projectors and rooms where the ambient light can't be completely controlled.
The reflections from the screen picture can increase the ambient light by reflecting light back on to the screen from the walls, ceiling, floor and furniture in the room. Thus Ambient light is not controlled just by turning off the lights, you must also have a projector room with dark walls, ceiling and floor, plus the furniture and fittings in the room should not have bright metal parts which can reflect light. If you cannot have such a setup, where the ambient light cannot be totally controlled, then a grey screen works best in such an environment..
Did you find the aluminum flake changing colour when mixed with the water based paint?
Yes, its true. This ll work exceptionally well with dlp projectors than led projectors. But more than contrast, colour is the main reason I think. Colour depth details of led is not even half good to DLP.grey screens are used to increase black levels but out of my own experience projector should be with good black level
in order to display true blacks and good contrasts
I have been using a grey color wall as screen for my home theater for more than 4 years. I was using Royale luxury emulsion from Asian paints
Color code is 0615 Silver Grey ( Grey shade ). Royale Luxury Emulsion is little glossy finish and was giving very good picture quality for a 2800 lumens Panasonic projector in living room.
Now i have repainted the same wall with Royale Atmos (same color )which is Matt finish.
https://www.asianpaints.com/colour/colour-catalogue.html
Thanks. I don't have any knowledge on paints. So just want to make sure everything before I hire a painter.
Currently my wall is in beige colour. Do I have to do any base coat before I paint to Silver Grey? How many coatings required to achieve a good screen? Any other mixes required?
My wall size is 10x11 feet. How many of litres/quantity paint required to cover my wall?
Also my wall currently contains a TV wall mount and some nails on top. All these things needs to be rectified before I start to paint my wall. Will this be taken care by the painter?
First of all, you need to get rid of any kind of any damages on the wall surface ( be it a nails/cracks / dents /mount holes etc ) and then use wall putty.
Painting guys used to apply wall putty and then sand the surface with sand paper to get perfect flat finish this will make sure there is no uneven surface and will be perfectly flat.
After sanding, primer will be applied to the wall and then the actual paint.
3-4 coats should be good enough and you will need at least 3 liters
Painting procedure below.
https://www.asianpaints.com/products/interior-walls/plain-finishes/royale-atmos.html
For a normal throw projector you can use a retro reflective paint mix, I use what is called the black widow ultra (an open source paint mix project). It requires a neutral grey water based paint and aluminum flakes (auto air fine). The aluminum flakes are not available in India but can be bought and delivered to India. For the base paint use asian paint royale interior paint (soft sheen) colour code (silver - 6142). This colour has a RGB value of 186,189,188 and its the closest you can get to the grey they recommend in the project.
Thanks for the details @danielnaveen2003
Ok.. LG PF 1500W has a throw ratio of 1.5, and there would be some slight indirect daylight in the room.. Would this be a concern?..
Is aluminium flakes similar to the ones that we call metallic paint feel that we see in automobiles?..
Hope asian paint royale interior paint (soft sheen) colour code (silver - 6142) is the only paint required for this DIY effort.. How many coats is required for a good finish?..
Roughly the screen size would be 75 inch diagonal.. How many liters of paint is reqd?..
The purpose of black widow is to combat ambient light. However from my experience from using it and other factory made ambient light rejection screens, I can say that they are very good at rejecting directional light like ceiling lights or a wall light fixture but not so good at rejection diffuse full room light (which is how indirect sun light is going to be like). Still better than a white screen though.
Autoair fine is precisely that
you will need 2 to 3 coats. Ofc you will need putty, primer, sand paper and rollers/spray gun
1 liter should be more than enough. Dont use the standard dilution guidance printed on the paint container (if applying with a roller), you want the coat to be slightly thicker so that the flake can be dispersed evenly
