danielnaveen2003
Ok.. Great..
Hope these flakes should be aval with car painters who do tinkering/dents work..
Hope Putty is chalk powder.. Painters call these "Patti" in tamil.. My room walls have been already plastered with putty.. Should i consider puttying the projection surface area alone once more before i begin the process?..
Thank you.. Just to get my self clear, in case i have access to flakes from car painters, how much quantity should i consider getting for a litre of paint..
I used acrylic putty which is more like a cream, its a poor choice for walls as moisture will make it peel off, but ya if your walls already have putty there will no need to apply it again. The original mix is 946ml of paint to 227ml of autoair fine (auto air fine is more like a metallic particles in a liquid base). Since you are gonna get some other brand, you can always experiment with the quantity. Too much and it will have hot spots all over too little and screen gain will be low.
