Denon 1612+ polk TL600 speakers
ksona
Hi All
I am looking for a good HTS system.
My purpose is watching movies, listening to indian music more and rare western music.
I am more interestd in clarity of sound and not more into more punching bass effect
I am looking for a good receiver with latest features likes wifi/network and can be remotley upgradable for any new features released by te manufacture
I have chosen Denon 1612 A/V receiver + Polk TL600 spakers. Is Jamo better than polk?
Please suggest whether my choice is good or is there anything better. Budget max 50K.
Regrads
Ksona
Its a good choice and please audition once before you make up on decision.. Jamo has wide range and especially 606 ranges lot much depth and works well.. POLK TL1600 are good combo,. You may try Denon 1713 or 1513 which has additional features.. depends how you budget it?
Hi All
Regrads
Ksona
Hi buddy,
You can refer to this thread where I have posted reviews of many 5.1 packages, which could prove useful to you.But still don't jump to any conclusion before auditioning it..http://www.hifivision.com/home-theater/34288-onkyo-4505-yamaha-298-denon-1312xp.html#post454229
http://www.hifivision.com/home-theater/34288-onkyo-4505-yamaha-298-denon-1312xp-2.html#post454725
http://www.hifivision.com/home-theater/35606-my-final-decision-denon-1713-wharfedale-dx1.html
And BTW Denon 1612 doesn't have network facility which you are looking for..
Hi friends
Thanks for the reply. I couldn't revert immediately. Could you alos suggest few reliable stores from where I can buy this .
Hi All
Finally i have bought the following
Denon 1513 with Diamond 10.1 speakers and thought of adding the rest later.
I compromised for USB and WLAN, which may not be a daily usage for me.
I got the entire combo for Rs.38600
Expereince:- Its excellent in sound clarity and yet to njoy movies in that. Also I need to upgrade my DVD player with HDMI compatible since mine is Analog DVD player.
Hi All
Hi All
Hey..Buddy
Congratulations..Enjoy..:):):)
Hi All
very very wise going for step by step.....it will blow you away...when you will add a centre a play from hdmi and original 6 channle audio...
save money for that upgrade..
enjoy...
very nice decdision for going step by step...wharfedale rocks..
no you did not make a compromise on usb...its really useless..as you will play it anyway from a separate player fro quaklity output..and wlan is used really say once in 5 years....:lol:
enjoy
Thanks. Its really impressive. To justify my decision I have palyed same audio in My Old Sony Music System (DTS and with Hybrid twin woofer spakers) and then played in Wharfedale 10.1......
Unbelivable difference and clarity in voice and music and every one in my family reliazed and accpeted by choice :) :)
Now looking for simillar guidanec and suggestion for a good and Blu ray playet with USB, DLAN, WIFI support I have shortlisted one from []Philips. BDP5200[/I][/B]
Any Suggestion please
Thanks to every one who suggested to go with Wharfedale and reivew posted in this thread....
enjoy...
enjoy
Thanks... to all the forum memebers who guided me for wharfedale with their Review posts....
HiFi forum rocks.....
Hi All
Could y0u suggest whether to go for Philips Blu ray player or stick to Pioneer BDP?
My confusion is, Since we have Denon Amp, Is it to spend 17k for pioneer or phillips (7k) will do.
Need your reviews and suggestions.....
Philips BDP3380 or PioneerBDPLX55
Hi All
Coukd you guide me on the which bluray player to go with. My thought was any way i have Denon1513 so why should we invest30k more in BDP.
Can the amplifier does the equivalent job with philips BDP ?
Any suggestions and comments
get sony 490 8.2k..mrp 13k
else import pana 220...9.5 including all.(can be made region free)
high end option..marantz..20k..mrp 40k..check hifimart itself...
best 3 options
best 3 options
Thanks for your input. As per my ealrlier exp Sony always has a problem in playing some DVDs and formats....
I will go for Panasonic ...? Any feedback on pioneer? i read some good reviews about that too....
I am in bangalore. But I am unable to get this model220 in Panasonic show rooms.
Also does this supports multi region?. How about the models 110 and 100?
Please assist me in buying sutibale player to use with my AVR1513
Sona
Hi Friends
Help me out on the finalization of BDP. My firned is travelling to singapore and thought of buying any one of this
1. Pioneer BDP450 - my concern is service centre and after sales support, incase if i gt inot any of the problems
2. Panasonic BDp220/110- i heard remote is a problem
3. Sony 490 - not sure whether it can play otyher than original DVDs and also can support all video formats
Please advice.......
I have no idea about the Pioneer but have both the Sony 490 bought in India & the Pana 220 (110V, imported via Amazon US)
The sony has absolutely no problem with dvds. I have played both original & pirated too. It probably is region coded for blu rays & haven't really tried other video formats.
Let me know which one you're worried about & I can check for you.
Hi Friends
