P prasadkatre1 New Member Joined Mar 1, 2010 Messages 16 Points 0 Location Bangalore Apr 14, 2010 #1 Denon Hi All, Regards, Prasad Last edited: Apr 16, 2010
spirovious Well-Known Member Joined Apr 10, 2008 Messages 12,847 Points 113 Location Mumbai Apr 15, 2010 #2 Try wharf 9.1 series,Q aco 1010/2020 series.
M maniac_2004 Member Joined Jul 22, 2008 Messages 344 Points 18 Location mumbai Apr 15, 2010 #3 spirovious said: Try wharf 9.1 series,Q aco 1010/2020 series. Click to expand... Hi Spirovious, will the denon with 90w be able to drive a wharf 9.1 (20-100 w) ? I too am considering this combo but am confused on this part .. How will the 9.2 denon combo be ?
spirovious Well-Known Member Joined Apr 10, 2008 Messages 12,847 Points 113 Location Mumbai Apr 15, 2010 #4 Many have used Wharf 9.1 set with Denon 1910 without any problem. Lowest power needed is 20 watt & Denon 1910 has 90,So no prob.
J jagvira New Member Joined Aug 15, 2010 Messages 1 Points 0 Location chandigarh Aug 16, 2010 #5 hi please tell whether focal dome 5.1 is appropriate choice for denon 1910???? regards spirovious said: Many have used Wharf 9.1 set with Denon 1910 without any problem. Lowest power needed is 20 watt & Denon 1910 has 90,So no prob. Click to expand...
