B balamdu New Member Joined Nov 11, 2012 Messages 2 Points 0 Location Bangalore Nov 11, 2012 #1 Hi All, Below is the set up that I have thought about, Denon AVR2113 FS- TSi400 Center - CS 20 Surround - OWM 3 Subwoofers - PSW 125 Can you please suggest will this combination work? Thanks, Bala
P prosenjit New Member Joined Jun 30, 2012 Messages 2,393 Points 0 Location india,kolkata Nov 11, 2012 #2 all combination work. but do it suit your ear or not depeneds..so a demo is very imp. also if budget isnot aproblem...go for that.. otherwise buy 5.1 sety upp now....buy surrounds later...no need of 7.1
Viren007 Active Member Joined Jul 8, 2012 Messages 37 Points 28 Location Delhi Nov 11, 2012 #3 add good sub instead of PSW 125, kind of boomy sound, it just a suggestion take a demo then decide.
HTuser Active Member Joined May 4, 2011 Messages 529 Points 43 Location Bangalore Nov 11, 2012 #4 I would suggest RTi series instead of TSi. You may go step by step if budget is an issue
B balamdu New Member Joined Nov 11, 2012 Messages 2 Points 0 Location Bangalore Nov 11, 2012 #5 Thanks for the responses. Can you please suggest any model in RTi series and a good subwoofer. Also any insight on KEF speakers with Denon 2113? Since I didnt get any response on AVR, can I assume that Denon 2113 still holds good? Thanks, Bala
P prosenjit New Member Joined Jun 30, 2012 Messages 2,393 Points 0 Location india,kolkata Nov 11, 2012 #6 2113 good enough... and yes now buy a centre and 2 fronts..... buy others later so u can spend the whole budget on qulity items....
F fran_elite New Member Joined Jul 14, 2009 Messages 204 Points 0 Location Mumbai Nov 11, 2012 #7 I am using Polk RTi A3 for Fronts, CSi A6 - Center & FXi A6 for Surrounds powered by Denon 2311 AVR & it sounds great.
HTuser Active Member Joined May 4, 2011 Messages 529 Points 43 Location Bangalore Nov 13, 2012 #8 2113 is good My suggestions Fronts - RTi A5 Center - CSi A6 Surrounds - RTi A3 or FXi A6 Subwoofer DSW 550i. I felt that Polk is more suitable for movies than KEF . (and KEF more suitable for music than Polk) balamdu said: Thanks for the responses. Can you please suggest any model in RTi series and a good subwoofer. Also any insight on KEF speakers with Denon 2113? Since I didnt get any response on AVR, can I assume that Denon 2113 still holds good? Thanks, Bala Click to expand...
Kittu New Member Joined Apr 5, 2010 Messages 5,349 Points 0 Location bangalore Nov 13, 2012 #9 Try the same KEF speakers with Yamaha a2010 or 3010 depending on your budget.
soamz Active Member Joined Sep 6, 2012 Messages 604 Points 28 Location Dubai, UAE Nov 25, 2012 #10 I got my system assembled today myself at my place. Denon 2113 RTi A5 CSi A4 Fxi A4 DW660
