recently i built a pair of stands for a couple friends
i realized they can be DIY'ed pretty easily
here's how i did mine
what you need
Solid wood - 1 inch thick
a couple selftapping screws
12mm black glass 5.5inch by 5.5inch
Some sand paper
Polish
Process
Cut out the wood using a router or jig saw - or hell, just get it cut from where you buy it!
6*6 inch - 1pc
5.5 * 10 inch - 1pc
use a file and cut out the notch in the centre of the longer piece on the top side leaving 6mm either side
the notch makes sure the headphones dont slip off
centre the taller piece on the sqaure base using the self tapping screws
sand of for a smooth finish
get the stand polished natural and use melamine if possible
Stick the glass to the base
The glass helps keeping the CG down and making the base heavy so the stand doesnt topple while using
Youre DONE!
here are some others one can try
Google Image Result for http://www.wooaudio.com/images/fullsize/hps2t-slv-headphones.jpg
Google Image Result for http://www.mains-cables-r-us.co.uk/1552-thickbox_default/oscars-audio-headphone-stands.jpg
Google Image Result for http://www.mains-cables-r-us.co.uk/1559-thickbox_default/oscars-audio-headphone-stands.jpg
Google Image Result for http://i01.i.aliimg.com/wsphoto/v9/729885291_1/Wooden-Omega-font-b-Headphone-b-font-Display-font-b-stand-b-font-font-b-Headphone.jpg
what you need
Some sand paper
Polish
Process
6*6 inch - 1pc
5.5 * 10 inch - 1pc
Youre DONE!
