Hi all,
I think I can use low power SET amp for some of my music. Am Looking for some DIY/semi assembled single ended Tube kits or good designs with easily available components. Should be simple to assemble. I understand with quality components they get expensive on logarithmic scale. Don't have any clue how much they cost. So no budget till I find cheapest good design.
Selecting Solid state design is very easy. That will be AmpCamp* by Nelson Pass. But As I have some tubes (ECL82) am leaning towards it more. Can buy new tubes also as nothing is fixed. I also understand safety measures with high voltages involved. I have limited understanding of electronics but I am looking for...
1) Most Important : Good well appreciated simple published circuit design. (Will be joy to start from scratch. Other too can join)
2) Low power 2 to 3 watts is OK.
3) No push pull design.
4) Am Ok with regular normal affordable OT.
5) No expensive tubes. (No 300B though they are V. Good).
6) Amplification stage Tube based but rest of the design SS is perfectly all right.
7) Chinese designs are cheap but doubt their genuine circuit design and components. unless some kind knowledgeable soul guides me to it.
8) P2P will be icing on the cake.
* Can anyone tell how much AmpCamp Amp. Only PCB+Components costs ? (No heatsinks, Connectors, enclosure etc.)
Thanks and regards.
Thanks and regards.
