Correct me if i am wrong - Steel pellets for filler will not dampen the sound waves .. they might resonate ... and the sound might have a metallic quality.
I've heard a sewer pipe effect from plain iron stands not filled with sand.
i think keith has explained well what i plan to do
			Stealing Chowpatty sand is always a good idea :lol: Just make sure you wash it well in Dettol laced water and dry it really well before you use it. Better get started soon because according to the met. dept. the monsoon will hit Mumbai in 4 days so what with this heat that we have here - drying sand will be a matter of hours now.
hmm detol laced water. didnt think of that.thanks for the up
BTW is taking sand from chowpatty allowed or i really have to steal it?
			Actually I meant damping between the granite base and the collar - with some rubber bushing - maybe.
yes thats very possible.actually i shud have done that
but what happened wa when i made the spikes i had a miscalculation on the lenght of the threads.they got short. i coudnt even spare 2mm to adjust a wiser.
Maybe ill make some more spikes later on
once again thanks for the idea keith.i should talk to you during my next DIY
			I think  alternating sand with steel pellets might be a good idea provided the bottommost and topmost layers are pure sand. Steel pellets will provide mass and sand will seep between the spaces between the pellets anyways. Might be overkill but wtf? Now if there were to be rubber tubing lining the inner walls of the pipe [stand]... Killer stands!
WOW you have read my mind. im trying to get that rubber lining done but silicone coating on the inners of the pipe is provin to be difficult.
im looking at simpler options likejust rolling a silicone sheet and pllacing it inside and then putting it ina powder coat baking oven,the silicone most probably will stick to the inners
other ideas are very welcome
			magma,absolutely great going on the stands.look damn cool,and being a stickler for detail shows
.love the spikes and collar.very neat.cheers
thanks for the encouragement man.
@cranky
thank you very much for the approval.
my speakers weigh in at only 12.5 pounds each
which is not much hence ive not planned for the balls on the top plate.
you are right for the balls to do their job  large mass is reqd.
i thought of just having a granite skirting with antislip silicone feet
