Hi APK !Used to own a first generation thunderbird 350. Great bike, but very difficult to maintain because of the problems that kept coming up. I've had all kind of problems - right from starting troubles to oil leaks to clutch cable break to rust. Ended up selling the 'bird' after a couple of years.
I have been reading on team-bhp and other forums that the bullet realiability has improved over the years. Am really tempted to try out either the classic 500 (really love the desert storm colour) or the new thunderbird 500.
Anyone who has bought a bullet recently care to comment on the reliability factor! I guess a bullet will never be a 'fill it, shut it, forget it' kind of bike!
Best,
APK
Happen to own 2 Enfields
Hi APK !
Yes...bullets of old were never the 'fill it, shut it, forget it' kind of bikes.
But it did not matter much as the alternatives were just as bad regarding the finesse and workmanship...
The situation changed with the entry of japanese models. Which has forced the manufacturer to improve, and the new Bullets are just as good if not better. The first generation of TB were particularly bad as they were learning at that time and transiting to the new bike. The Bullets which are available today are quite mature and maintenance-free. But apple-to-apple, please be prepared to spend more time and money on Bullets compared to other bikes.
I have an old Bullet. In its entire existence of 36 years it has leaked oil only for around 5 years or so. There was a crack in the engine base and it was too small to warrant the repair expense and I was lazy too.
Finally one day I got it repaired. I ended up spending money(the entire engine has to be taken apart) but its been fine since then.
regards,
Jawed
Friend of mine is taking delivery of the new bird in october, so if you can wait till then - will keep you posted on how it runs - problems wise
Long trips planned on it so should give us the 'feed back' pretty soon
Best,
APK
I always wanted to own one and thinking of pulling the trigger.
My usage would be very limited - as commuting to work on office in delhi/ and return in night is out of question. That would give me couple of kilometers on weekends. On the other hand, do not have time/ inclination to sit with mechanic every weekend to get it fixed. For reduced usage, reliability is even more important.
What should I do? Buy new for reliability, or buy old for budget? Any suggestions, or if anyone who is willing to sell one in VGC. Pls help.
Very nice!
BTW, did you change the stock tyres on the TB? Seems a bit wider than the one that I had.
Best,
APK
Yes, both have wider track tires at rear
what size and make of tyres do you use? I remember the MRFs on the TB 350 that I had were pathetic.
