I wrote an email to hifimart and they said these speakers need an amp or AVR i think they are not sure about this.
Boston Acoustics Soundware XS Digital Cinema loudspeaker review - Loudspeakers
by this i got that the subwoofer has an inbuilt amp and which powers the 2 satellites.
I am confused some what :sad:
I bought these speaker from HIFIMART and got delivered.i talked to anil (hifimart owner or representative) about it,he said speakers are passive but sub-woofer is acitve(i think he means in-built amp).
I want to connect it to my tv,but it doesn't have RCA cable input/output(only speaker wires).Is there any way to work around it or i need to buy amp/avr?
I thought it does'nt require an AMP, I have ordered this for my desktop;
I think it takes the 3.5 mm audio jack cable.
Thought 14.5K is an absolute steal for that. The reviews were also good.
The optional part is that if you have the receiver you can connect the speakers directly to the receiver instead of the subwoofer.
@Bakes14: you would require a RCA-3.5mm cable, something like Amazon.com : ER 6FT 3.5mm Mini Plug to RCA Hook Computer To Stereo 6 FT : Rca Mini Cables : Electronics.
You can get an inexpensive one in stores.
Please connect it thru digital optical cable. You don't need to buy an AVR for it. Please see the following youtube video and pay attention to the last part (2 mins 30 sec): Boston Acoustics Sound Ware XS - YouTube
Is your model and the model listed in the hifimart.com below are the same?
Boston Acoustics SoundWare XS 2.1
I thought it does not require an AMP, because the product manual attached shows the speakers being connected to the sub which has a built in amp.
Please find the link for product manual, which does shows that : http://ap.bostonacoustics.com/DocumentMaster/ap/SoundWareXS21_npa.pdf
The sub has a speaker level input and output. It still needs an external amp.
Regds
