LordKitchener
I got in to HiFi pretty suddenly and kind of jumped in without knowing too much.
I have a bit of a 'strange' setup I guess.
Equipment:
- TV
- Pro-ject Primary E Record player
- Raspberry Pi DIY Streamer
- Triangle LN01A Active Speakers
- Schitt Modius DAC
- Behringer MicroPhono PP400 Preamp
My setup is like so:
- TV -> Optical -> DAC -> RCA -> Triangle LN01A Speakers
- Raspberry Pi Streamer (Volumio) -> USB -> DAC -> RCA -> Triangle LN01A Speakers
- Record Player (Pro-ject) -> Behringer MicroPhono Preamp -> RCA -> Triangle LN01A Speakers
I have a very basic pre-amp for my Record player. I have this as it's a fair distance from my speakers and I read that quality can drop over distance with Phono, so I send it direct to the pre-amp and then via RCA to the speakers. The phono cable on the Pro-ject primary E is fairly short too, so it made sense to have a pre-amp.
I recently read about people sending DAC signals to a preamp, before sending to the amp (in my case the active speakers).
I'm not sure how necessary this is?
I'm not overly happy with my setup due to the remote situation. I have to manually switch sources on the DAC. I use the Triangle remote to control volume. I have my TV remote. I'm not sure I want to add another thing to the setup.
Any advice would be great. Eventually, I'll probably remove the TV from the config, but for now it makes sense in my apartment. I think I'll be happier with the TV removed so that the setup is simplified.
Equipment:
- TV
- Schitt Modius DAC
