corElement
I have a feeling this will fail miserably and harm the future rep of hd in india.
Is it in Tata Sky?
jatinsoni200654 said:@KDM FROM ESPN HD Too![]()
sanjay0864 said:That looks awful. Someone please tell me that logo looks like that due to some screen capture issues. God save the games coverage if it is going to look anythign like this.
No, I just checked. DD HD is not listed on the TS HD guide, yet. I think he's using a computer based system to view DD HD.
<snip>
Cybersurfer, do you have any idea of the data rate being using for PQ/sound by DDHD and the codecs involved for both? Also, is it possible for you to post a two or three minute .TS clip? I'd like to see what this looks like on my TV.
Looking to see a "Tinka" (a particle of hey) in his beard ? (Chor ki dadhi mein tinka as per a Hindi Proverb).This is absolutely great news now we can see Kalmadi uncle in Full HD.
Although I would prefer moving images, I would not say no to the colour bar with audio. Two odd minutes should be enough, I think. If anything, it will provide some insight into DD HD's audio quality.
No audio at the moment. Will provide a sample when the audio is back but don't expect much they are just using audio of some of their other channels. Sometimes in this channel you can hear 2 different audio streams at the same time (overlapping).
Is it in Tata Sky?
any body have any idea abt this.
Format : MPEG-TS
File size : 168 MiB
Duration : 2mn 2s
Overall bit rate : 11.5 Mbps
Video
Menu ID : 1100 (0x44C)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 2mn 2s
Maximum bit rate : 9 707 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Duration : 2mn 2s
Maximum bit rate : 196 Kbps
Video delay : -1s 414ms
Language : English
Menu
Format : AVC / AAC
List : 510 (0x1FE) (AVC) / 610 (0x262) (AAC, eng)
Language : / eng
BitRate_Maximum : 9902800
Downloaded it. MediaInfo reads the fileinfo like this:
But there's severe stuttering/freezing when playing the file on a BDP-S370 although the counter updates smoothly. I didn't expect the audio at play at all, given the AAC codec, but the stuttering is what's got me puzzled. I will try it on my PS3, which is lying around disconnected since I got the S-370, later, and report back.
