DVP or BLUE RAY PLAYER
RAJUSH26
pimpri
Hi friends, I need any of the above for playing local 100 Rs MP3 and DVD's, budget 15000 max. TV: LG 47 LA 6200 , Audio : Stereo amp and speakers arrg. Thanks.
If you are going to play only local Rs100 mp3s and dvds (assuming they are pirated), then there is no use of buying a bluray player. Just go for a dvd player and it seems you have a very good budget (Rs15000!!!) for that.
DVD player will be enough but since your budget is Rs 15000/- you can go for a bluray player if you wish to see HD content in future.....
Can branded BD players run pirated 100 rs mp3 and DVD's.
Yes it can run any cd and dvds if it is a region free player.for ur amt 15k you can achieve that .Pana220,230 and pioneer 450 or good models for regional free player.If u r ok with indian region player u can get blurayplayer starting from 5k .Go for bluray as it is future proof.Don't go for dvp it is utter waste of 15k for that .u can get good sony dvd player with 2k.
