Enclosure for my DIY made Crescendo Millennium Amplifier
good build
congrats
trafo
so close to the Ip and Op signals??
trafo and cap bank positions could not have been switched ?
it seems you have access to metal shops
how come you didnt go with aluminium front and rear plates
glossy Plexi looks good only for a while plus an all metal cab would be better in controlling interferences no ?
good build
congrats
trafo
Ur Right trafo and cap bank positions could have been switched... Didn't looked at it during Assembly (because of this there is slight hummm, which for a while is acceptable to me)... But to to open it right now and do the wiring again its a headache.. I will have to go again through all the Drilling Process, Wire Extension etc... So let it burn for a while then later on i will give it a shot.
If i could have gone with the Aluminum plates, then I would have not achieved this finish Plus the Cabinet cost would have gone up. However this both cabinets are my First DIY try with Acrylic sheet, So lets see how long it takes to shade away the glossy finish...
Sadik
Looks awesome
And Finally The Project is Completed :yahoo:...... Some Pics along with K Buffer..
WnRSp0cxlCKLC-hQqnHup2qz5P-1lo5K84Jcgl1IJEByeATKfSwatK5ZBaZ1P5vRqAqQtVIgSubm2NAdKK1b-MOKNk5zomFemck7z70GXXfg7bpP-tlo4SvvQSfAzHMxUBc280YS94wIIMg3ah6rDuVf0Z8udp0xT4rvmD26vnfrT1UiZqT-3T75M-4jS0BqAOK-UCHD6lJmWu8qY6A-C-zgHGNL3DOcIamVmf4rZAmD3glgAhe2eo0Gjq1IfSZrhnCSNU2ZRRMq41pmJRE_tzGCrOIZ1hirqyhsjhB1LiYW82rwvi5_8FCOqBLh2v9GNaVUV8e4kV9RqIN7h3XUa5Kcnr6yjpm7fv6zhBbDWysE7WxwbKtWdvW1ATuOodPTRlfu-gUnzRtUZV-YpP5tfP-mW4GfQEjtn9l67bILE9btrXWrIGD9raxaXatvl6YQe0pIwlBpG0dfntdHQgS7VfYvWwWh-G8UqYcJ-zmcsPq9cxVay9I3exccb0xtFAaVXEnU9us2CkXTi1PHNExYyeZgROkPNtyjqgAtUiqCLD8HDD_m57AcasmaZbaCmHb3sRRr=w1227-h920-no
MomjznXcR2CqjFWvT4b-cY7PLotyxBtHhidJhy9duZYv5V4q_lNfg-44yRRkOv8k4GPWaW8VXJ00aB39U2P8_Xym20ND7jAjDV14uOslfVnDLKg_v-Mx3lH-LEVMFTdGx1F_6-jvZpd512usxTc9lwHLwwoKJ1SNqUnCqUNQFGFA77Xkjyl6Ay8QuHlgHHk8SUmWvC7hHAY_aValzN-K9Q-8JQ41GkCvMtFCC6NnsCEMMmA0V3CsIBTuWiIileo40VE0IlgItmylMjeoUxg-ZX6vJBRyq1ked-b1593W4HJlDswMmCWdXz-Dn57odjO9IWW0UHEMB30WNW5AyiRQLRKu1NR7-yXPzBeeuczue0YQdUw9JHNnhvtK5iRilqk5zwl8-LsECJ9DWvK_T7ZeNg2uvTSwderb_QA4Or1xatXZYMl8J68Z6f83OYGDg7bgPc-VjQ1JzXYQboPOixqjSwRmvT0tI68QtiJ8wo9DbFlYX9yBJGrUiIwEFp_UeTE_oRfdk57g6FumfaZ7NB0h6er9uND2hKcCNr5PGWih67AiPVAOXRG_z-LsfxV-d8syearF=w1227-h920-no
JdD_HX2KufW1K8rDsY-Qi44L6c7Ss9VGvEXbxnBAqh7xfjQbPvT0P0-8Nb6r3f97oD_kG8NNKugNSI3ymCJiBzwSHUTzcTmNC4d4G0tqVXEkE9wYbgeqveydE0AqYbJ4SRm6xOb1MnLMFFtQ49U-9g_TMbm2L9TYTTiSyXea6jjLxTkocNSaYX1pQaKnZh821qWiqRumpEgficnzx5ZZy34sTlwR0t0fMwUUKLSDNjd1p3uNweWkG3enl3vqLx7CnuHqvYCdKNR7w1Y8CrfT93H5SQrLN5gOsMKcAg0szB0S_XRD4KUvZVgkDfN3tVUgeZD-dyj7nYMwwgdOXzDqZ-yH-Q4TXiVuWTG4UCYqpTTtUGoW_CEoblJimh5-Y_cbPyGcZRMWNt4JY9rAysssEwsqycmfQ2umzyYAPUDtwnf_7Xa68Utc4Q15wqXkni_vPS8sR-_UgIs5czOEoSUrCSsps6RGjM3pK7bTHXWoCSObLFJXPAxiwNcTFrhd5In8t1jDY1GcHVVMl88fOby9IKrCyr62-iSfS7IswxFzS5W4aavxrTEx8QLoJ61yRGMA30nu=w1227-h920-no
Sadik...
Excellent work ! Very nice DIY. A noob suggestion. You can use microphone cables for Audio in. They are twisted and with separate shield. I guess you can keep shield of the wire open. Another noob suggestion is you can use Transformer cover like this Link. Enjoy the music. :)
Regards.
Regards.
Any guess about the material used for the Cover? Making Cover will be easy job for me.
Sheet metal can be used. You can experiment with a sheet metal strip bent in to circle.
Regards.
Mumetal is best, but basically unobtainium. Mild steel sheet of about 2mm will work well.
