greenhorn
I've ended up in the UK for a one year term, and have already started missing my speakers - A LOT.
#1 priority is not to lose a lot of money during resale at the end of the year
#2 priority is Good sound
#3 is Reliablity (can't be bothered to run around fixing things here, unlike in India where i used to be on the lookout for non working stuff)
#4 Good Looks
I'm torn between 3 choices
Option 1
Microlab Solo 7c
I have a solo 5c at home, and am happy with it except for the bass. This should take care of it.
Option #2
New Amp and speaker combo
Something from Richer sounds or superfi clearance. I'm guessing this will still end up a bit expensive (around 200 pounds for a decent entry level bookshelf and amp)
Option #3
Used amp and speaker combo
Ideally I would have preferred this route - the prospect of getting a 3020 or a B&W on the cheap is really tempting, but I'm in leeds, and the options here are pretty few -
Gumtree - Mostly DJ equipment shows up. Hi Fi is far and few in between
Ebay - mostly click and collect ads. Used equipment sells for atrocious prices, typically 100 pounds or more for 70's integraded amps with faults!
I know option 2 should be better, but is it worth the increase in terms of sound, and will it hold any resale value better?
is there any place I'm not looking at for #3?
#4 Good Looks
Option 1
Microlab Solo 7c
Option #2
Option #3
