Audition few systems today
1. Denon 1612 + paradigm cinema 70 - (lot of sound clarity)
2. Denon 1612 + canton - (small speakers, not much impressive)
3. Denon 1312 + wharfedale ms100 (wharfedale seems to be bright, i wud prefer neutral to warm)
4. JBL cinema 300 (looked good vfm)
5. Marantz + Jamo (out of budget)
plus few more with denon avr
Out of all these, i liked denon1612 + paradigmct70. Price - 56k
2 questions
1. Does this combination looking good as per technical specs and match. For my primary requirement of movies, is this combination good or should i be looking at some other combos.
2. Can i consider paradigm speakers with denon1312 instead of 1612 for budget considerations. Dealer advised that for my room size 17ft by 9ft, 1312 is as good as 1612
Thanks in advance
I'm glad you have been able to demo quite a few systems. Paradigm sounds like a good choice which would also match well with Marantz. Denon 1312 and 1612 both are rated at 110W RMS, so they both have the same power. 1612 has a lot of features along with Audessey auto calibration which is absent on the 1312. When it comes to audio always go for what sound you like irrespective of what others might say. If you prefer a warmer sound then also demo Marantz.
Jamo A 102 HCS 5 Home Cinema Systems also should fit in your budget. Have a look :
Jamo A102HCS5 review from the experts at whathifi.com
Another good one : Boston Acoustics Soundware XS
Boston Acoustics Soundware XS review from the experts at whathifi.com
