Hi Guys,
I am facing a problem with my recently purchased LG 47LH90 LED backlit LCD TV.
Once I got the TV, after playing around with picture settings of the TV quite a bit, I had found my optimal picture settings (these settings were derived from settings suggested by users in online forums of highdefjunkies.com and avsforum). Once I was satisfied with picture quality I saved these settings in a profile.
Now, the problem is, everytime I switch on the TV, the picture looks very bad - foggy, bluish etc. Now, I need to go to brightness control and bounce it by a notch ( i.e. say if saved brightness level is 52, I make it 53 and then back to 52 again). Then only the complete settings take effect and picture becomes right.
Effectively, everytime I switch on the TV, I need to do this circus before I can start viewing. (how frustrating!)
Same problem happens if I change inputs. My tata sky is on AV1, while my dvd player is on component1. So, I just switch to the other input, and picture becomes bad. I again need to bounce brightness level to get it back.
I made a complaint to LG. Their technician came over and saw the problem. He went back saying he needs to check with senior engineers. It has been two weeks now, and still no response or solution. Everytime I call them they say they will check and get back. But no getting back so far.
The problem does not happen, if I use the default settings - where in white level (grey levels) control, red brightness/contrast, blue brightness/contrast etc at default setting of 0. But, then the picture quality is not satisfactory to me at the default setting.
As many of you will be aware, one USP of LH90 is that amount of picture settings control that it provides. This is one of the primary reasons for it getting good reviews by cnet, avsforum etc as well as by all users.
This played a big part in me selecting this TV over others.
I am posting this information for the benefit of potential buyers. I am suspecting that this is a generic problem with all sets of this model. Most likely a firmware issue (or some hardware component issue?) such that settings do not get applied initially till brightness control is bounced. If it is a firmware issue, may be it would be possible to fix it - not sure though. I am not sure whether this is the only manifestation of the problem. May be there are other scenarios where this will happen.
Please be aware of this problem if you are considering this TV. I will update this thread if I hear back from LG.
For more detailed information on this problem, see below some relevant parts of the mail that I sent to LG support.
I have my favorite picture settings stored under the name 'expert1'. (this has my customer brightness level, color, white levels
CMS etc set.
Now, everytime I switch on the TV somehow the settings do not take effect. The picture looks hazy, foggy, bluish etc. Now, I just to picture control and just modify brightness level up and down. (my stored brightness level is 52, so I just need to make it 53 and then again back to 52). Suddenly, now the settings take effect and picture becomes perfect.
So, in effect, everytime I switch on the TV, I need to bounce the brightness level once to get proper picture. Same thing happens
when change input source (AV1, component1, HDMI etc). Same problem with saved settings in expert2 also.
For your reference, I am giving below the picture settings with which I can see the problem. This is just an example. As I mentioned before, I can see the same problem with a variety of other settings.
Picture settings:
o Backlight: 45
o Contrast: 83
o Brightness: 52
o H Sharpness: 54
o V Sharpness: 58
o Color: 66
o Tint: R3
o Expert Control
Dynamic Contrast: Off
Noise Reduction: Low
Gamma: High
Black Level: Low
Real Cinema: On
TruMotion: Low
Color Gamut: Wide
Edge Enhancer: High
White Balance: Cool
Red Contrast: 20
Green Contrast: 9
Blue Contrast: 26
Red Brightness: 3
Green Brightness: 14
Blue Brightness: 16
Color Management System
Red Color: -5
Red Tint: 3
Green Color: -3
Green Tint: -4
Blue Color: -3
Blue Tint: 3
Yellow Color: 2
Yellow Tint: 0
Cyan Color: -5
Cyan Tint: -7
Magenta Color: -3
Magenta Tint: -1
