sharadgaur
A small square room is the worst case you can have considering the acoustics point of view http://www.avsforum.com/t/1256145/is-square-rooms-bad-for-bass. To get a decent sound quality, you would have to invest heavily in a lot of bass traps. This needs to be taken into consideration while planning an ht room. A rectangular room whether L shaped or otherwise is likely to sound much better with moderate acoustic treatment. In case you decide to set up ht in the square room and If you are not able to invest in that kind of treatment, then I feel any other expenditure on cabling or equipment would be a waste. Just some friendly advice from own experience , not to discourage you. Also you can google 'thx viewing distance calculator'. A screen too large can also ruin your av experience.
