sanjeevrao453
Yes, I watched GR research channel and its quite good for beginners.On youtube GR research has a nice channel - maybe you might look at the episodes where he builds the same speaker you are building
good luck !
DiY is good fun and keeps the brain ticking !
Please suggest. I attached the x-over diagram. Please suggest which place should I put it. From the internet, what I can read it should be fitted between Vcc and Ground to prevent noise.Good solution.
Since you're building an XLS, may I suggest that you add additional bypass capacitors to the capacitors in the cross overs? I use polypropylene caps on mine and it took the sound to a higher plane.
