sachi
Had a quick question on ground noise.
I currently have the ground wire from the turntable conencted to the chassis on my preamp.
WHile this reduced the ground noise considerably, its still fairly audible once i go past the 11o clock position and quite annoying when listening to the quieter passages on a track.
I notice that when i touch the tonearm and the power switch on the turntable together, the noise floor drops another significant step which would be acceptable.
Any idea what could be causing this? I am thinking of running a wire from the ground wire on the turntable which should be connected to the tonearm body (correct me if i am wrong) to the body of the power switch.
Someone on audio circle recommended that i re-wire the cartridge, but i doubt if this is the problem. Nonetheless will check it out.
Should i be looking at something else instead?
___________
Next, need to invest in vinyl care. Thinking
1. disc doctor fluid.
2. VPI or disc doctor brush , one for wet and one for dry cleaning.
3. Zerodust stylus cleaner
4. digital jewel scale for tracking force measurement.
5. Lint free cloth. Does chamois work well here?
Anything else i might have missed?
Thanks for any input you guys can provide to a clumsy vinyl noob in advance
___________
