@sashijoseph: thanks for the pointers.
Last night I rechecked the supply voltage to the LM3886. I think I've been measuring it wrong all along. I used to measure pin 5 (V+ input) referenced to speaker negative and it showed zero. I measured pin 5 with reference to pin 7 (Ground) and it showed around +62V. Since pin 5 is shorted to pin 1 as per the circuit schematic, I checked pin 1 wrt 7 and the same +62V shows up there too. So I guess this is the reason why the chip is not sending an output signal to trigger the speaker relay since there is about 20V more voltage than the absolute continuous maximum of 42V.
Now the question is how the hell is the rail voltage almost doubled?
I didn't dare check the V- pin 4 yet, but I will devise a way to check it safely without shorting the multimeter probe to pin 5.
@quad: thanks for the link to Linuxguru's schematic. I installed Eagle and could peruse the correct schematic now. Hopefully it will translate to better troubleshooting.
