Heavy Discount on Cyberlink Powerdvd 17 Ultra
mandeep
Mohali (Near Chandigarh)
If you want to upgrade or purchase new CYBERLINK POWERDVD 17 ULTRA software ,then it seems , now is a good time.
I have been waiting for the same for a long time, so wanted to share ,so that if somebody wants to purchase or upgrade can benefit from it.
For Upgrading:
Earlier after discounts + coupons , the minimum price possible was = ₹ 2000/- approx
Use the link below to get lowest price of ₹1562.71 by using coupon EXTRA30P instead of WOW20
https://www.cyberlink.com/stat/edms/bb/powerdvd/17/17w51/retail/enu/us/index_ult.jsp
For Puchasing New :
You can also buy the new one (If you are not upgrading) for ₹ 2,009.83 , similarly using coupon EXTRA30P instead of WOW20
To purchase new copy, one can go to the cyberlink site (by google search ) or use link below for convenience
https://www.cyberlink.com/products/powerdvd-ultra/features_en_US.html?affid=2581_1274_728_43492_0_ENU&utm_expid=5598521-554.2R4lYKRcSNWB-c7opB11xQ.0&utm_referrer=https://www.cyberlink.com/index_en_US.html?r=1
and use the option "Add to cart"
(For both select Currency "Indian Rupee" from the option list at the top right.)
Cyberlink IMHO is a very good option as it is quite stable and you also get updates from time to time and you can also post in cyberlink forums if you have any problem.
what sweetened the deal for me is that with the upgrade as i am also getting a lot of free software's such as "Media Expresso 7.5", which can now convert 4K video files, 4K videos can be converted to H.264 or H.265 versions (yet to try).
Other free software's are "Power2Go 11 Platinum", CyberLink Screen Recorder" and "Power Media Player MR" along with 30 GB cloud space
This offer is Valid Upto 31st december Only
Cheers and a very HAPPY NEW YEAR TO U ALL.:):):):cool::cool:
Thanks but the link does not open
Try again, the link is only for those who want to upgrade, for others who want to purchase new copy, they can go to the cyberlink site by google search or use link below for convenience
For Upgrading:
For Puchasing New :
How is PowerDVD compared to Kodi / MPC?
Is it worth spending 2K on PowerDVD, if my playback is limited to 1080p?
Please advice.
Please advice.
Cyberlink is very user friendly and quite stable( rarely hangs my PC) , if later on you want to add ultrahd drive and play ultra hd discs (not much compatible hardware available as yet), It can play bluray files with all the menus etc, picture quality is much better now with pdvd ultra 17 and good support and updates.
Please advice.
Kodi + madvr requires high end hardware configurations, as it uses lot of hardware resources to be entirely beneficial. Though many people do report getting good results with moderately good hardware. But there is a lot of customization you need to do before you get good results with an average hardware configuration. I use both, but like powerdvd more, due to ease of use only.
More then power dvd,i liked acrsoft total media theatre, the picture and sound quality was better then the former.
But unfortunately no updates from them..
Thanks. Bought one.
