Help! Chord Mojo stopped working
@Analogous once fixed, do let us know the source of battery acquired and technician details as mine one is also approaching end of battery life.
it’s possible with the Mojo 2, but not the version 1
Marvellous tech and engineering let down by stupid battery structure, not sure why in first place , they did not think about this. 😥
Let me take my words back
I opened my mojo , disconnected battery and connected directly to power socket and it's getting on and working perfectly.
@DB1989 sir, so it can be turned on by just connecting power line and disconnecting battery.
So coming to your problem, please try below diagnoses if not done already.
1) Please check if while powering on , do you get that 'cut/click' sound , just to make sure if button is not worn-ed out on circuit board.
2) Try same after opening the mojo and pressing buttons on circuit directly.
3) Please use another 5v charger and check if it is getting heated after 15-20 mins by touching mojo steel body.
4) If no, may be power board is fried up. 😪
Thank you so much for this help and suggestions. Opening up your own Mojo to test this is very generous of you. I am grateful.
