nubinstanley
Hi All
I am planning to buy a 5.1 system. I'll talk a little about my needs and also about the research I have done so far.
Requirements :
1) Budget <= 250000 (I don't plan on putting any more money into the system in the near future. Maybe add 2 height channels after a while)
2) My TV is setup in my living room, which is pretty large (~30 x 14). The only option is to have the TV parallel to the shorter walls and so, the sofa will not have a wall behind it. (planning to setup the surrounds on stands)
3) I do listen to music, but the the primary use would be for movies.
4) I would prefer to keep most of the speakers from the same brand (not an absolute necessity).
After some research, this is finally what I had decided (kinda) :
AVR : Denon AVR-X3600H
Speakers : All from Q Acoustics
R/L : 3050i
C : 3090Ci
S L/R : 3020i
SW : QB12
Final points:
1) I read very good reviews about the 3050i and they look nice as well. The other options I had considered : Elac Debut 2.0 F5.2 (6.2 is a lil more expensive), Fyne Audio F302/303 etc.
2) I also read very good reviews about the Q Acoustics 5.1 Cinema pack as a whole (except for the 3060S SW). The Fyne audio center speaker (at least the one that came in their 5.1 pack) did not have very good reviews and that is where I took Fyne off the list. Keeping in mind requirement 4 , I decided on the Q Acoustics pack.
3) I decided to swap out the 3010i (that came in the pack) with 3020i for the surround.
4) Subwoofer - This is where I am most confused. The QB12 looks solid and have good review (very few though). It is sealed (and huge!) and I am wondering if I should get a ported one as my living room is pretty big. I was considering the SVS PB1000 and from what I read, even though it is ported, it is pretty good for music as well. As in, it is pretty tight and accurate ? (Though I am still inclined towards the QB12 for the aesthetics and also since it does have good reviews; and again - requirement 4).
5) The lowest offer I have right now (for the above pack including AVR) is 235000. Decent ?
Due to the covid situation, I am finding it difficult to find a place to try out the speakers. I have a visit lined up for this Saturday. Lets see how it goes.
I have pretty decent ears. But I would not describe myself as a full fledged audiophile. So, if the AVR/speaker set I have mentioned above are pretty good in this budget, and if the alternatives would not make a hell lotta difference, I would just like to go ahead make the purchase. Please give suggestions.
Requirements :
R/L : 3050i
C : 3090Ci
S L/R : 3020i
SW : QB12
Final points:
