mudit
Please help me select a TV.
Location of TV: Corner of a Room. About 4 feet from ground on a TV table.
Viewing Distance: 15 feet, when watching from the same room (70% of the time). Approx 30 Feet when wife watches from Kitchen
Viewing angle: Viewing angles will not be extremes.
Usage: More than 80%, normal SD content. Possibly Tata Sky (have to take one). Possibly some HD channels. Might buy a blue ray player as well for occasional HD movies. Might hook up tablets once in a while.
Preferences: Would like to go for the biggest possible (but not bigger than 55 Inch TV). 3D not a real need. Smart TV, not a real need. Picture quality should be the best. Sound quality o.k. o.k. would be good enough. Might add a home theatre in near future.
Models on radar: Sony 46 inch W950a. Approx price: 1 Lac Rupees. Based on general analysis, I tried to find Sony 55 Inch W950a (not 950b). I might be able to get the 55 inch 950a model for approximately 1.5 Lacs.
Budget: 1.75 Lacs. ( Sony 55 w950a + extended warranty will fit in in the budget).
Experts please advice.
Is 55 inch too big for my needs?
Sony 55 W950a is a better choice over Sony 55 w950b?
Also if the recommendation is to go with Sony 55 W950a, how do I check and ensure that I am getting a fresh piece (as I know that it is a discontinued model).
Any other model/brand that you would recommend?
Do I need to buy a voltage stabliser?
Any other gyan?
Mudit
Any other gyan?
Mudit
