First of all, thanks to a lot to all the active members in the forum who answered my queries earlier while I was trying to start my hifi journey. I ended up buying a Yamaha RX V373 from pepperfry and a pair of used bookshelves - Lektor 2 from our FM Bobby.
While the AVR reached in perfect condition, the speakers were not so lucky (due to poor packaging and handling). Below are my queries:
Lektor 2 speakers: There are 2 visible damages to the speaker.
1) First one is - the points of the grill are broken. I am not so worried about this one and will try to fix them at home. Even if they don't get fixed, the speakers look good without them.
2) Second one is - each speaker has got 2 front firing ports. When I removed the speakers from the box, I could hear some object moving inside the speaker. After some time, I realised that the cylindrical pipe like thing in one of the ports has broken/dropped inside the speaker. My heart just sank but I thought let me connect it to the AVR and check. To my relief the speakers are playing but I am not sure if this will impact the sound quality. I have the following options:
i) Leave it as-is and continue using the speakers
ii) Take it to a service center and try to get it fixed
iii) If FMs suggest, do a DIY and open the speaker panel from the front to see if that port can be fixed
Please let me know what should be done. Attaching the pics (DCS01937)
The next question is - I bought 4 pairs of DAC banana plugs to connect these speakers. The banana plugs are fitting nicely into the speaker but not in the AVR. Is there some other type of plug that I need to buy (Image - banana plugs)?
Thanks in advance,
Rikhi
Thanks in advance,
Rikhi
