Dear Gurus,
Been following this forum for long, but this is my first post (better late than never!)
Background -
# was planning to buy a TV for long, was not sure which one (LED/LCD/PLASMA) or which make (Panasonic/LG/Samsung)
# Criteria was - 42" +; must play SD content well; must be Full HD; must play HD video files thru USB (I don't have BR player); low power consumption
# Scouted around, read posts in net (including hifivision of course!)
# Panasonic LCD - not impressed with PQ (especially SD), Plasma - high power consumption/no HD support on USB
# Samsung Plasma - SD was "horrible" (C550), LCD/LED were good but heard too many bad reports re after sales service
At last went to Croma (Jayanagar 9th block) Bangalore, purchased LG 47LE5500 at 80k + 2.5K for 2 yrs extended warranty. No point in discussing win/lose now, it's done! BTW, got the Tatasky HD at Rs. 2599 for ICC (they are broadcasting HD - opening ceremony was a blast!)
Observation -
HD Content is outstanding even close up (I sit around 12 feet away) - played via USB
HD channels are excellent (via HDMI)
SD channels are quite good (via HDMI); bit washed out if you are up close (3-4 feet) - but don't expect better with 480i.
Black tones could be better - have heard it can do great blacks, but not sure of custom settings
Doesn't play m2ts video files or DTS audio
Quite a few HD movie files are "video only" as the set does not recognize the audio format; per manual, should play AAC LC, but sometimes it doesn't
Question for Gurus -
I have a Compaq CQ42-139tu laptop with HDMI out. If I play the TV "unplayable" videos (which play well with audio/video) in my PC via VLC and connect the TV via HDMi, will it play both audio & video on the set?
Is there any way to improve SD content viewing experience vis some "expert mode" config? (Picture settings are exhaustive, but not sure what most of those mean)
Is there anyway to improve the whites/blacks ? Current settings are not outstanding to see
(I tried this - LG 47LE5500 picture settings - CNET HDTV picture settings Forums but am not quite impressed)
Background -
Observation -
