Appu,
+1 to saketb's suggestion . Go for digi 200 and you are set for more devices too..
But buy it with bill and warranty.. I'd also recomend using an MX / Belkin surge protector along with the stab...
MX surge 6 port with filters will be 650/-
Kittu
kittu,
surge protector should be connected before the stabilizer or after it?
Stabilizer -> Surge - > HT components.
I have 2KVA Servo Stabilizer whose o/p is given to all sockets except High Power ones (AC / Fridge) . Do I need to buy separate stabilizer for my LCD+HT+Digicomp ?
Also when light goes off and Inverter kicks in , LCD restarts and we watch it for an hour or so on Inverter power. Inverter is not sine wave , am I killing my LCD ? What you guys suggest ? Should I get UPS instead for LCD and its components ?
I Think you should go for APC UPS for all your AV components....All branded UPS have internal MOV bank (Metal Oxide Varistors) which protect the equipment from surge & spike.....Moreover, APC line interactive UPS have AVR inside (Automatic Voltage Regulator) which takes care of power fluctuations also..
I dont understand why are we after UPS? Is it for backup or protection from fluctuations?
If it is for backup, go for good online ups which is a very costly affair. Else go for a good stabilizer something like servo or equivalent with atleast 40-50% extra as reserve (at full load).
Note: You should never use any line interactive UPS for your AV power protection, its better connect directly to the power line
Line Interactive is a cheaper option than online and should always use it to safeguard your costly equipments.....LI UPS have voltage regulator inside it which is a must for managing the fluctuations....
A normal LI ups of 1KVA cost around 11K with 10 min backup and an Online UPS would cost you around 21K for same backup time
