Help required to fix Norge 1000.. Please
rockingx
Delhi, India
Hi Friends,
I own almost 2 years old Norge 1000. lately I found that sound of one of the speaker was more than that of other one.
I replaced the volume pot with new one. I had to replace B100K with B50K pot as I could not find B100K at that time. It started working almost 90% better.
Now I got few B100K from one of my friends (brand ELCON, found in Lajpat rai market). Today I replaced the pot with the new B100K but lost the sound of the amplifier.
After replacing the pot, there was no sound at all. I heard the click on powering up/down in speakers but nothing other than that sound. No sound in RCA cable, nothing at all.
I thought there could be some problem with the new pot, so I replaced it with another one but the problem remain same. I then changed it back with the old one (B50K, which was working earlier) but the problem still persist.
I found some sound while touching the soldering points of the volume pot (on the preamp PCB where the pots are soldered), but no sound from any source.
I don't know if preamp PCB got damaged while soldering the pot or if there is any other problem.
Can anyone please suggest what should I do or try now? I don't have much knowledge of electronics but can do little bit of soldering.
If anyone can suggest where I can get it checked and repaired in Delhi
(preferably in North/East Delhi..that will be great help.
I am looking for support from all of you.
Thanks a ton in advance.
Hi, if its not have been done, It could be useful in getting the amp checked in LajpatRai market. You should be able to get some help there.
