D DR MUDHAN New Member Joined Nov 29, 2014 Messages 5 Points 1 Location Chennai Jun 11, 2024 #1 Dear All , planning to buy DENON AVR. Kindly guide me which one is better X580BT or S660H. Pricewise not much difference. Thanks.
edjamesx Well-Known Member Joined Dec 7, 2007 Messages 769 Points 63 Location Bangalore Jun 11, 2024 #2 DR MUDHAN said: Dear All , planning to buy DENON AVR. Kindly guide me which one is better X580BT or S660H. Pricewise not much difference. Thanks. Click to expand... Go with X580BT, looks to be better in terms of their specs.
C caspian1985 Active Member Joined Dec 25, 2021 Messages 221 Points 43 Location Mumbai Jun 11, 2024 #3 edjamesx said: Go with X580BT, looks to be better in terms of their specs. Click to expand... I’d check out the Onkyo SR-3100 - should be similar price, much more power, calibration, Dolby Atmos, which these two Denons don’t have
Vishram karande Active Member Joined Feb 21, 2021 Messages 102 Points 28 Location Palava city Jun 12, 2024 #4 G DR MUDHAN said: Dear All , planning to buy DENON AVR. Kindly guide me which one is better X580BT or S660H. Pricewise not much difference. Thanks. Click to expand... Go for AVR having minimum power of 80 watts at 8 ohms, at least few years will be away from upgrade thought.
D DR MUDHAN New Member Joined Nov 29, 2014 Messages 5 Points 1 Location Chennai Jun 12, 2024 #5 edjamesx said: Go with X580BT, looks to be better in terms of their specs. Click to expand... Thanks for your kind response.
D DR MUDHAN New Member Joined Nov 29, 2014 Messages 5 Points 1 Location Chennai Jun 12, 2024 #6 caspian1985 said: I’d check out the Onkyo SR-3100 - should be similar price, much more power, calibration, Dolby Atmos, which these two Denons don’t have Click to expand... Thanks for your kind response. Is ONKYO SR-3100 available? Can you suggest some seller in Chennai or Bangalore?
D DR MUDHAN New Member Joined Nov 29, 2014 Messages 5 Points 1 Location Chennai Jun 12, 2024 #7 Vishram karande said: G Go for AVR having minimum power of 80 watts at 8 ohms, at least few years will be away from upgrade thought. Click to expand... Thanks for your suggestion.
C caspian1985 Active Member Joined Dec 25, 2021 Messages 221 Points 43 Location Mumbai Jun 12, 2024 #8 Check Modern World/Modern Radio in Bangalore. They have an Onkyo brand store +91 77609 88162 DR MUDHAN said: Thanks for your kind response. Is ONKYO SR-3100 available? Can you suggest some seller in Chennai or Bangalore? Click to expand...
E efernand1 Well-Known Member Joined Jul 6, 2012 Messages 6,074 Points 113 Location Mumbai Jun 12, 2024 #9 DR MUDHAN said: Dear All , planning to buy DENON AVR. Kindly guide me which one is better X580BT or S660H. Pricewise not much difference. Thanks. Click to expand... Would suggest you contact Anil (HifiMart), he will offer a good deal where possible once you finalise the AVR or he also could possibly suggest another good AVR which may suit your requirements.
Lizard King Well-Known Member Joined Jun 5, 2020 Messages 527 Points 93 Location Hyderabad Jun 13, 2024 #10 DR MUDHAN said: Thanks for your kind response. Is ONKYO SR-3100 available? Can you suggest some seller in Chennai or Bangalore? Click to expand... Onkyo has gone bankrupt. Best not to put your money in that brand.
C caspian1985 Active Member Joined Dec 25, 2021 Messages 221 Points 43 Location Mumbai Jun 13, 2024 #11 Lizard King said: Onkyo has gone bankrupt. Best not to put your money in that brand. Click to expand... No - Onkyo and Pioneer got bought by Voxx who also owns Klipsch ( https://www.forbes.com/sites/marksp...nd-thanks-to-premium-audio-company-and-sharp/ ). They have new distribution, new products, and have been back in India for 2 years - I bought a Pioneer LX-505 a couple years back and have been very happy with it
