If you have Monitor Audio Bronze as front then don't think about any other brand. Monitor audio Bronze center is one of the best center speaker available for you. Little expensive ( 20K after discount) but worth for what you pay. Other than that I like the most is WD Diamond 220C ( 17K ). Boston acoustics A225 is also good option but can't compare with MA Bronze center and as suggested by many FM , front three speakers must be of same brand with same series for seamless integration between three speakers.
Had budget not the constraint, I would have certainly gone for monitor audio. I am planning for subwoofer (bic f12) so budget is limitation. Boston acoustics a225 is available at 10k. But I don't see any good review. Is it worth? Other options are Polk T30 or Tsx150c . These are available around 7k/12k. If these are not good then I can max stretch my budget for WD220c. Please give your valuable feedback. For Boston acoustics I am not sure if there is dealer in Polk. For Polk I shall try to get audition.
