TyCongrats on getting the speakers....
Did you say you want to hang a 10 kg chandelier? Then only you will get the right screws.....refer to svs manual for gauge of the screws required....
How much did they cost you? I got the svs from us and it costed me 22k which I find justified for their performance. I am yet to install them.joined this discussion very late. Hope the costly SVS gives you good experience for your atmos effect. To just add, I use 2 pair of JBL control 1 mounted on ceiling. It comes with mount options and also has an additional dependable chain which will hold up the speaker from falling (just in case the screw fails)
I find it cheaper, effective & secure.
I have auditioned the jbl control one x and they are decent for Atmos. Max HT chennai has them set up for Atmos demo@Murlidher: ^^ Thats a very timely post for me. I am looking to get some Atmos (concrete) ceiling speakers for myself and had shortlisted the MIssion M-cube and the Sonus 3450.
Just wanted to check your experience with Atmos on the JBL ? Are they good and how much did you get it for?
Sold for 12k at Amazon.And where can i buy this speaker from?
I mentioned that I have auditioned the control one x only for Atmos^^ Those are the Control X .. Which are outdoor speakers.. they are usually not that great for Home Cinema use. Control One are indoor speakers.. more tuned towards Home audio applications..
I used the same plugs and screws I used for the Yamaha speakers. Don’t know the specs just went with my guys that it will holdCongratulations.....what screws did you use? (Gauge / Thickness)
Sure will monitor them.Alrighty!
But keep monitoring it once a week or fortnight ...to check if it is giving way slowly or not!
This means taking a ladder or high stool to climb up when fan is off and checking!
This is the screw I am using. Wall plugs I don’t have extra to take pic. Length is 1.8 inches. Holds the 3.2 kg easily.Congratulations.....what screws did you use? (Gauge / Thickness)
