Ok there are small bookshelf speakers with key hole slot. You can use mounts and install them. Aso jbl, Sonus speakers come with mounting kit which can be used for atmos
Which Yamaha speakers? Also, which AVR and what are the other speakers connected to system?i had used this method to mount yamaha entry-level htib bookshelves on my hall's ceiling. can be swiveled sideways & up-down.
I initially installed my yamaha yht99 HTIB speakers in the ceiling using mounts from amazon. Please refer the below linkWhich Yamaha speakers? Also, which AVR and what are the other speakers connected to system?
Can you please share a few pic of the installation?
Help with Atmos speakers in concrete ceiling
No proper website for them. visiting their showroom is the only way . Ok I will visit the showroom do they have a demo?www.hifivision.com
superb please share picsI ended up installing Taga 606 speakers on concrete ceiling using mounts from amazon...![]()
Sharing a few pics including that of the setup.superb please share pics
clean and looking superb. What about your rare surrounds ?Sharing a few pics including that of the setup.
I didn't use the screws and drill bit that came with the kit from Amazon. I used 6mm fastner bolt and for that I had to get another 8mm drill bit. I have a B&D hammer drill that was deployed to execute the concrete drilling. Everything DIY.
thank you somuchAt rear I have Taga 806s
And on question on tilt, please see the images below to get some idea
Their Micca M 8C have great reviews on Amazon US for the price they offer.Can Micco Covo S available for 4K in Amazon give good result for atmos (ceiling mount)
For concrete ceiling this cant be usedTheir Micca M 8C have great reviews on Amazon US for the price they offer.
