Hi friends, iam from hyderabad
Tanoj
great to see the lp's back in hyderabad,
looking to buy pre amp, power amp, turntable.... and speakers
budget is 50-60 k , pls suggest
hey buddy, welcome to the forum.. we have diffrent sections for all of it. please go through them see if you can find anything suitable. .our audio geeks are always there to help..
Thanks for the reply,
iam confused to decide between avr or amp,
i listen to music only, and want it to be crisp and clear , like a live performance.
right now i have a Philips Af - 834 , vintage turntable. sounds good but i belive cartridge needs to be replaced.
iam happy that the new movies vinyl are comming back, but are they using master print for manufactring them, or what iam listning to is a fabricated music... just curious
Hi Tanoj, Welcome to the forum. If you take some time off and search the forum, you will get plenty of information on the forum. BTW, in your budget of 50-60k, I'm doubtful if you would get a Pre, power amps, LP and speakers unless you go on the pre-used route. I just bought an Acoustic Portrait Pre and Power amps which itself cost more than the budget that you have mentioned for the entire setup; Just to give you some idea.
Welcome to HFV.
You can go for a TT, intergrated Amp and speakers.. once you search the forum and get an idea about what you need to buy, you could then visit some shops in Hyd. Also ask the fellow members from your city for recommendations.
within that budget i dont think you should be looking to go separates imo in the amp section. a good speaker around 25k is the usher. you can also check out the bookshelves of monitor audio bronze, kef q series, wharfedale diamond 10 series. again at that budget bookshelves give you better bang for the buck and def better sound quality. as for amps once you've decided on your speakers you can audition nad, cambridge, marantz...
hi iamfrom karimnagar u can call me on9490193553 ATC SCM 110 PRO ACTIVE TRI AMPING SPEAKERS and JVC DIL-A projector rs 50 and velodyn dd 18 sub woofer pair pioneer ELITE 09 bluray pairs AND MARANTZ 9004 BLURAY WITH MORE THAN 550 BLURAY TITLES HAA
Welcome to HFV Nazeer!
Hi Nazeer,
That is an impressive set of equipment you have. It may be a good idea to introduce yourself in the Introductions section.
Rajesh
