sound_maestro
Hi All
I am now in Kochin and looking for a decent sound budget system,since computer audio systems fail to impress me anymore.My main need is for music which is encoded in 5.1 format(ac3).I will play them from computer and pass it on to receiver via HDMI, at times some computer games(FPS). I would rather have a system all be ready now since infusing funds would be difficult in future for this project.I like floor standing speakers and could use a receiver which has USB in front and ARC ,other things like (network,WiFi,Airplay,3D,pandora,Spotify more than 3HDMI in etc) are useless for me.My impression is Yamaha receivers are a better than Denon(also warranty is in Chennai),marantz is good for Music but expensive.
Going over the various valuable threads for speakers under 75k ,50k and 45k here is what I found to be good,unfortunately they are difficult to audition here.I am thinking of using the upcoming trip to Chennai to try and buy speakers and receivers.Is there a single place where all this can be listened to?
Any more to look at or consider?
- Yamaha 299 - almost impossible to find but about 35k and sounds good or if I am lucky a used system.
- Yamaha 375 + Jamo Jamo S626 HCS3 --> They seem good as per the forum
- Boston Acoustics Soundware XS 5.1 + DENON X-500 5.1 for 38K
- Aj 5.0 for about 35k and a used receiver stretching it to 60k
