Home theater speakers to pc
n_crazyreds
Delhi
i have a 5.1 lg home theater system
i want to connect the speakers and sub woofer to my pc, they have wires like these connected at the back of the system/dvd player...
what is the cheapest way to connect them to the pc without using the dvd player...
What input options do you have at the back of your dvd player? You might be able to connect the pc to the dvdplayer .. its not just a dvd player - it is a player and a receiver built in the same box so if it accepts external inputs then you can try connecting your pc
you cannot seperately connect speakers and sub to the pc as they would need an amp to drive them that is built in the dvd box..
check for the inputs available at the back of DVD player ..
