Home Theater within 30k
chirantan
hasnabsd
I am new here. I want to buy a home theatre system within 30k to watch HD channels & movies. Plz suggest.:signthankspin:
@Chirantan, please go through these threads and get a generic understanding on what all are needed and generally recommended. If you have any specific questions, we are happy to support
I have gone through many threads... now I have shortlisted 2 system...
yht 196 & sony ht iv 300..
which 1 should I buy?
Sent from my Lenovo K33a42 using Tapatalk
Im using yht196. The bass is not so heavy... but it is an awesome system in every other way possible for that price. For movies it is 9/10... for music it is 7/10. With this avr, you can upgrade speakers later, and add an active sub too !!!
Neither, these very entry level ones are not known for performance. Instead use a PC/Laptop with a USB sound card such as the Asus Xonar U7 and connect to something like Swans M20 5.1, the performance will be better than entry level systems such as the Yamaha.
I will suggest you to double your budget before you venture. 30k is too low to start this hobby, if you are interested in quality sound
No budget is small. Yht 196 will provide good upgrade as compared to TV speakers. Later you can upgrade to better front speakers and active subwoofer when budget permits.
Else you can look at HTR 3067 plus nsp40 speaker package. It will sound better than yht 196 out of the box and has active subwoofer.
Sent from my ONEPLUS A3003 using Tapatalk
it will take some time as my new room is under construction. I want to know a thing from u. will u help?
People select brands like Sony, Philips,Samsung, LG so on.. however let Pine Tree State guide to you one not thus acquainted product of Yamaha-Yamaha YHT196 five.1 full vary acoustic sort. (Yes, Yamaha doesn't sell solely comfy bikes ! )
> Design - sturdy(bit bulky) and classy
>Current price at Amazon : Yamaha YHT196 5.1 full range acoustic type
> Highlights : Comes with sub-woofer, excellent performance, superb sound quality
> User Reviews/Ratings :
Sound clarity : 4.5/5
Wireless property : 4.1/5
Value for cash : 4.7/5
Performance : 4.1/5
I really likable this product. it'd utterly suite your bracket !
If you're a whole client, and need to urge the sleek, gorgeous look of Sony. you'll check this product further :
Sony HT-RT3 5.1 Soundbar
> Design - Sleeky
> Check deals at Snapdeal, Amazon & Flipkart- Sony HT-RT3 5.1 Soundbar
> Highlights : Attractive design, good bass effect
Sound clarity : 4.2/5
Wireless Connectivity: 4.1/5
Value for money: 4.3/5
Performance: 3.7/5
These options are best for your price bracket !
Choose wisely !
Thnq guys for ur reply... just last one thing. I have bought yht 196 but I have not installed it yet as my new room is getting constructed. I have a concern that my tv does not support ARC. I want to connect my blu ray player & HD set top box to the AVR. will I able to listen to the sound of set top box on my speakers?? or I have to do something else?? plz do reply. thnx
As informed over PM, it will work fine. Even my TV doesn't have Arc
YHT-196 is very good for Music and Movies but it has following disadvantages.
1. No active Sub woofer.
2. 4K doesn't supported.
But Yahama has introduced another HTib with above features.
you can think of it which cost you around 32000/-
It's Yamaha YHT-1840. you can try it. specs lucrative.
One more thing YHT-196 price decreased to 23000/- in Reliance Digital considering new model arrival in the Market.
OP has already purchased YHT-196
