How to check usage hours of Sony Bravia LCD
Is this process working on your Sony Bravia?
  • Yes
    Votes: 24 92.3%
  • No
    Votes: 2 7.7%
  • Total voters
    26
Based on the several posts above I interpret my numbers 05116-00022-00004 as
05116 - Total power-on hours. Yes this unit is over 30 months old.
00022 - Total number of reboots. Meaning number of times the unit has been disconnected from wall outlet.
00004 - Number of hours when the panel was powered up since last outlet disconnection.
that should explain why some have seen low number of Panel hours.
Hope this helps.
Anyone tried the service menu with the 2023 remote. My model is x90l and there is no info/num buttons and there is no way to check the panel hours
When the tv is turned off use the following sequence
Home -> Select(centre button) -> volume up -> power
The TV should be completely OFF (with just the power supply on) or on standy mode.? Also all these buttons one after the other or all at once?
