How to listen FLAC from my PC to my 2 ch sterep set-up at about 20 ft distance?
Well what you need is a "balun" (balanced to unbalanced audio
transformer) along with a CAT5 cable. A Balun prevent ground loops, and reduce hum and crosstalk, by using each twisted pair in a fully-balanced mode.
Using a balun and CAT5 you can easily cover 1000ft without the above issues. The only problem is if you would be able to find Baluns available in Delhi.
A list of Audio Baluns can be found at the below link ...
Audio Transceivers
The first 3, the 5 and the 7th one should be the one you would probably need .....
