Now for an great USB/eSata external enclosure.
This might do the job: Transcend Desktop HDD Case USB 2.0 + eSATA - www.deltapage.com
Whisper quiet.
Noise levels have been minimized to less than one sone virtually below the threshold of human hearing.
24x7 reliability.
These drives are designed to last in always-on, streaming digital audio/video environments such as PVRs, DVRs and surveillance video recorders.
a loudness of 1 sone is equivalent to the loudness of a signal at 40 phons, the loudness level of a 1 kHz tone at 40 dB SPL
I bought an MSI E350 board instead, which did the job very well, but unfortunately had to be returned for overheating issues.
The MSI E350 board could not be replaced and a refund is on the way. As soon as I get it, I'm picking up the E35M1-M Pro. It does come with a CPU fan, but using it is just optional. I'm going to try using it without the fan. If you don't want USB-3 and that CPU fan, the Asus E350M1-M (non-Pro version) is almost 2K cheaper.
I don't know. In practice it might mean almost nothing, but, in theory at least, we want to know that the bits that were on our CD have been written to our disks, and when we read them from the disk, we can feed them to our sound cards or DACs without alteration. This is why people go to the trouble of using drivers that keep the sticky microsoft fingers off the data as much as possible, because they do not deliver our musical bytes as written and read. Some of us spend so much time chirping away at "audiophiles" about error correction in the digital domain, and here's a product that seems to consider it un-important. I don't think I'd buy one for a music machine, and I am probably not an audiophile!@Thad
What do you think will be the implications for an audiophile PC for a drive that skips error correction?
That strikes me as very odd to the extent of wondering if it is a misprint! Surely any media-playing machine is dependent on consistent disk reads, and disk writes make no odds whatsoever --- perhaps a very small percentage on CD/DVD ripping times. In fact, albeit only on a cursory thought or two, I can't see much point in highly optimising write performance anyway: buffering and cache takes care of that.Also the features are optimised for writes which we rarely do for playback.
Jitter is a timing error in the reading of bits when converting to analogue, and is only going to matter when they finally arrive at the DAC, be it soundcard, usb, or whatever. I don't think it can be caused by a disk. However, it is something I have to look up every time I need to think about it!Given an audio PC that does nothing else but playback music, a desktop Caviar drive should not introduce too much jitter. Besides reading FLAC/WAV is not the same as redbook and data can still be readahead/buffered.
I was pottering about, window shopping on the internet, when I came across WD AV-GP hard drives: WD AV-GP
Apparently these are HDDs optimised for AV use. What attracted me is:
And to a lesser extent:
I have no idea what a "sone" is, so I asked wolframalpha to convert 1 sone to dB. Apparently such a conversion is not accurately possible.
Wikipedia says that a "sone":
And lower down, they say:
Normal talking, 1 m away = 40 to 60 dB = ~ 1 to 4 sone.
That doesn't sound exactly "whisper quiet", but maybe in a real application it will be better than a regular HDD. theitdepot lists a 1TB (3Gb/s, 32MB cache) WD10EURS at Rs.3480.00, which means it must be just above Rs.3000.00 on the street.
Does anybody have experience with these drives? They sound perfect for HTPC/Music PC applications.
Ahh, yes, good pointThese drives are designed to work in DVR boxes specifically. DVR boxes write continuously
On a desktop, writes and reads have to happen "concurrently" over a larger time slice (measured in 100s of msecs?) hence HDDs have advanced algorithms that optimize buffering and read-ahead, and selection of sectors and cylinders for writes, in such a way that head movement is minimized on subsequent reads thus reducing latency. Moreover there may be assumptions made about the statistical distribution of the size of concurrent read/write requests which may fall into a certain KB to MB range per second (OS paging, office apps). So the algorithm on this DVR specifc HDD may be tweaked to sequentially read/write larger MBs in a single operation with a larger time slice now dedicated per operation.I can't see much point in highly optimising write performance anyway: buffering and cache takes care of that.
Jitter is a timing error in the reading of bits when converting to analogue, and is only going to matter when they finally arrive at the DAC, be it soundcard, usb, or whatever. I don't think it can be caused by a disk. However, it is something I have to look up every time I need to think about it!![]()
Your imagination on this is better informed than mine!Ok to tell the truth, I am imagining things here
The last time I looked up jitter, I came away with the information that, whilst in the digital domain, it simply doesn't matter. The writer gave a rather extreme example of copying from digital data to digital data (DAT tape in his experiment) but, even after multiple generations of digital copy, with jitter, could still get perfect data at the DAC when finally listening to the music.
Your are correct. HDD's access the OS vitals, drivers and most importantly the swap space very often. Every time you access any data, HDD is reading it and at the same time, storing it in the swap space too. That's why the recommended practice in the serious workstations and servers is to use one dedicated driver for all the OS operations and programs. Then they use another larger drive just for the data. In Linux, they even go one step ahead and create a dedicated partition on OS drive for swap space. This way, the HDD reading head does not have to move back and forth for swap space/OS operations/programs and data.On a desktop, writes and reads have to happen "concurrently" over a larger time slice (measured in 100s of msecs?) hence HDDs have advanced algorithms that optimize buffering and read-ahead, and selection of sectors and cylinders for writes, in such a way that head movement is minimized on subsequent reads thus reducing latency. Moreover there may be assumptions made about the statistical distribution of the size of concurrent read/write requests which may fall into a certain KB to MB range per second (OS paging, office apps). So the algorithm on this DVR specifc HDD may be tweaked to sequentially read/write larger MBs in a single operation with a larger time slice now dedicated per operation.
Ok to tell the truth, I am imagining things here as I read about these things a decade or more backhyeah:
Excessive delay in reading , system bus bottleneck, cpu scheduling, poorly designed or implemented usb/spdif/firewire chip on mobo, all can add to jitter IMHO
--G0bble
